Satellite Direction Finder
Dish alignment, tracking guides, and installation tips.
Sat-direction is a simple and effective way to locate any satellite without using a compass or any other device. All you need to know is where you are and know how to look at a map.
Choose your location on the map
Select the target satellite from the list
That's it! The green line indicates the direction of the satellite with respect to your location!
Return to “Dish Tracking & Tutorials”
