[E² Plugin] Bouquet Maker Xtream
Legal IPTV tools, player apps, utilities.
smith
Developer
Developer
Has thanked: 4 times
Been thanked: 5 times
Spain
Unread post by smith »
  • For the moment BETA
KiddaC Wrote
This is 100% beta early release version.
Its not fully functional.
No 720 skin (HD) at the moment only 1080 (FHD)
Its for testing only. I really wouldn't use it as your main bouquet creator at the moment.
It can be installed along side jedimakerxtream as its a totally new standalone plugin
There will be dragons.
There may be memory leaks.
There will probably be crashes.
What's working.
Adding Xtream Playlists
Adding External Playlists - no building bouquets for these yet though.
Adding Local Playlists - no building bouquets for these yet though.
Main Menu
Add playlists
Main Settings
Delete Bouquets
About
Main Settings
Most should work
Delete Bouquets
Playlists
You can create Xtream playlists bouquets. (that is all at the moment)
Delete
Xtream Playlist Info
Bouquets Settings
Everything except Vod Bouquet order. EPG Offset. Don't think alternative epg is working either
Choose Categories
Everything should work. And you can hide categories and/or channels
It will build a max of 1000 series streams. So best to unselect everything and just add the ones you want to test
Progress bar
I have kept this very simple. It should show processing live, processing vod, process series.
What isn't working
Building bouquets for external playlists
Building bouquets for local playlists.
There is no catchup in EPG at the moment.
Auto Update isn't coded in yet. So you will have to keep manually creating bouquets to refresh data
Any EPG fixing or offsetting.
Return to “IPTV Tools Download”
